High idle while driving, seems like stuck throttle
Old Nov 10, 2000 | 05:01 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
When I drive the ECM idles the car at 1500-2000 untill I stop or tap slightly on the gas. Sort of like a stuck throttle. I do not have a binding throttle or linkage. I replaced the TPS because it was not giving smooth increase. No change.
I also found the TPS sensor was rubbing on my Accel 58mm throttle body. Filed it down, no change.
Hooked up my scanner and the IAC (stepper motor) is ay 47-50 steps during the high idle, according to the book it should be 25 steps. This I think is causing the high idle. I am not 100% sure though.
What drives the IAC and why or when?
I am not along with this perticular problem, read other peoples comments and you will see. www.thirdgen.org/messgboa...00129.html
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Heads, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine belt setup, Dual IROC Fans.
http://www.sethirdgen.org/octride.htm
Old Nov 11, 2000 | 04:04 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
The IAC is driven by commands from the ECM. The PROM is programmed with a desired idle speed and the ECM sends voltage to the IAC in an attempt to maintain that RPM.
The desired RPM changes depending on the conditions of the engine - cold start, warm start, open vs closed loop, etc.
I use Diacom to record the desired idle speed at various engine conditions and the RPM does vary a lot until the engine goes closed loop.
Guys on the PROM board could give you more detailed info.
Hope this helps.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
perZ
Aug 15, 2015 01:17 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
