a/c blows cold mist
Old Sep 4, 2003 | 01:46 PM
Akshay's Avatar
a/c blows cold mist
My a/c system blows cold. But sometimes blows cold mist. Looks kinda cool though, but car starts to smell afterwards.
I don't think the evap. hose is clogged, since there's a puddle of water under the car.
Akshay
Old Sep 4, 2003 | 05:11 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
like steam? my beretta does that sometimes, not exactly sure why, might be a vacuum leak causing the hot air to mix
Old Sep 4, 2003 | 07:40 PM
Vader's Avatar
That can happen with an extra cold evaporator (slightly low charge pressure), high blower speeds, and high humidity intake air. The air does not have enough time in the evaporator case to remove enough humidity, but droplets form after the air leaves the core. This is a precursor to evaporator icing from the low charge.
Old Sep 10, 2003 | 11:17 PM
Akshay's Avatar
update...
I ran my a/c on a higher setting for a week, and had no mist comming out of the vents. So I guess, the lowest cool setting, makes the air too cold...causing mist.
Maybe the expansion valve is faulty. My passengers love the mist effect though.
Akshay
Old Sep 12, 2003 | 05:20 PM
Vader's Avatar
Perhaps you should consider selling tickets to your "mobile sauna/humidor"....
Old Sep 12, 2003 | 06:32 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
I havent seen any problems with GM's but other makes (DC) are know for poor location of the evaporator drain tube and when they get plugged this is common along with water on the floor board. So where were you mudd jumping?
junior419
Apr 7, 2025 11:35 AM
wigmobile
Feb 26, 2025 02:56 PM
blackz281le
Jan 11, 2016 07:51 AM
bryan623
Sep 19, 2015 10:13 AM
scottmoyer
Sep 7, 2015 07:06 PM
