compression ratios
Old Sep 4, 2003 | 02:36 PM
IROCZ88x's Avatar
Car: 1988 IROC-Z
Engine: LB9
compression ratios
im in the process of researching building a new engine...i am familiar with compression ratios somewhat and what affects them but there is a lack of specific information...i just want to see if i can clear this up...
what is the minimum campression for a performance engine (in your opinion)
what is the maximum compression a car can run on pump gas and without having any problems?
what are the benefits of higher compression?
what range of compression is optimal for a street performance engine (in your opinion)?
thanks guys
Old Sep 4, 2003 | 02:45 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
with everything perfect, cam, extra, a aluminum head motor can go up to around 11:1 CR on pump gas, but that takes tuning, the right cam, and 94 octane gas(quality) all the time, I would say to stay under 10.5:1 and above approx 9:1, I would go (and planing to) about 10:1 CR, that way, any premium gas will be ok, also, the higher the compression, the morepower you make, due to more fuel/air in the chamber(per volumn)
Old Sep 4, 2003 | 02:50 PM
IROCZ88x's Avatar
Car: 1988 IROC-Z
Engine: LB9
what kinda of things can u do to drop compression? besides changing the pistons and heads...porting the combustion chambers? or thicker head gaskets? how much could gaskets drop it? thanks
Old Sep 5, 2003 | 12:59 PM
trbodon21's Avatar
Here is a pretty good tool to calculate your compression ratio.
http://www.sdperformance.com/cr.php. You will be able to change various parmeters and you can see the differences in the compression ratio.
InfernalVortex
Apr 20, 2021 11:31 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
