got some question on rebuild(heads, cam, rockers and so on..)
Old Nov 12, 2000 | 07:28 AM
z28wiz's Avatar
This is for a 305? Ok the l98's are allum. and i can get brand new ones for about the same price as the torquers which are cast iron for $600. Whats the advantages of each? Also which would be a good cam(roller) for my application. I switched from tbi to carb i have a 625 carter carb. The block is gonna be .30 over, i have 3.73 gears and an auto 700r4. Also which roller rockers would u suggest 1.5 or 1.6 whats the advantages of each of those too
91 RS' TBI 305
mods:
dynomax exhaust, lakewood control arms, gutted cat, pioneer deck, tbi spacer, jet stage 2 chip, K&N four inch element and open element, accel cap and rotor, moroso plug wires, msd blaster coil, bosche +4 spark plugs. Alot more mods to come!!(update 11/01/00 pulled engine
visit my page http://www.geocities.com/motorcity/pit/8410
2001 camaro SS LS1 onyx black, SLP dual/dual center exhaust which brings horsepower to 335hp and 350ftlbs of torque, T-tops, 6 speed, Hurst shifter, cags!, power everything
[This message has been edited by z28wiz (edited November 12, 2000).]
Old Nov 12, 2000 | 08:36 AM
Jester's Avatar
I'm moving this to General Engine.
Old Nov 12, 2000 | 01:14 PM
ede's Avatar
ede
i'd get a set of heads made for the 305. the chambers will be matched to the smaller bore. for a cam i'd run about .45 to .48 lift and 200* to 210* duration.
-=ICON MOTORSPORTS=-
1st & 3rd
Old Nov 12, 2000 | 02:53 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
L98s arent worth 600 when you can get a set of vortecs and a performer RPM for less than that. Not all L98s are aluminum either. The ones on camaros are cast iron. Youll have to get the vortecs milled 45thousanths to keep a good compression ratio and Id go with the 214/224 duration @ .050.
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 280 grind. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter
13.24@104
Old Nov 12, 2000 | 02:55 PM
mtx28's Avatar
i agree w/vortec.. vortec heads make much more power than l98's
[This message has been edited by mtx28 (edited November 12, 2000).]
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
86White_T/A305
Aug 17, 2015 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
