1992 V8 350: Where Engine Number located exactly?
Old Sep 7, 2003 | 08:14 PM
camarosource's Avatar
Car: Custom 1992 Camaro Z28 25th Anniver
Engine: 5.7L V8 350 L98 TPI
I'd like to view the engine number of my engine however can't find it.
My understanding is it's on the front right side of the block. (Left side if standing in front of engine). But I can't find it.
Do you have to pull the engine out to see? There is so much engine area. where exactly?
If I were standing in front of the engine, looking to the left, WHERE EXACTLY is the code?
Old Sep 7, 2003 | 09:30 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
I assume you mean the serial number cast into the block. For this stand on the left side of the car and look behind the cylinder head. It won't be easy to see. Try a flashlight and an inspection mirror. You may need to clean the area of crud to see them. Hope this helps...
BTW, why do you want the casting number? Just cuz or are you trying to track down info about your car?
Old Sep 7, 2003 | 09:43 PM
No, not the casting number.. The Engine ID Number..
Tells you the plant, month, date, and engine (codfe)
There is also one with it that has the Make of vehicle, year, plant, & sequene number.
http://www.yearone.com/updatedsingle...gineinfo3.html
I looked and don't see any ledge with this.. I can't see anything really too much since the AC pump is there.
Old Sep 7, 2003 | 10:01 PM
Here are pics I took
1. http://www.camarosource.ca/where_eng_id_1.jpg : Front of engine, left side.. You see the AC pump.
2. http://www.camarosource.ca/where_eng_id_2.jpg : Looking down that section.
3. http://www.camarosource.ca/where_eng_id_3.jpg : Close zoom of that section from the side of the engine.
4. http://www.camarosource.ca/where_eng_id_4.jpg : Really close up view (notice a "C23" on the housing.. what that?).. But you'll notice there apparently is no shelf with that Engine ID. Also I tried moving the wires there and what I could move I seen nothing underneath..
So WHERE is this engine ID?
Old Sep 7, 2003 | 10:12 PM
rustybluebird's Avatar
Car: 87 Firebird
Engine: 350, 416's, 230/230 cam, torkerII, q-jet
On my old "627" 305 block the "shelf" looks more like this.
Attached Thumbnails 1992 V8 350: Where Engine Number located exactly?-engintro3.jpg
Old Sep 7, 2003 | 10:14 PM
but if you look at my pics.. there is neither.. And I (struggled) lifted the wires out of the way and saw no shelf at all..
Old Sep 8, 2003 | 09:43 AM
Drew's Avatar
You're gonna have to get that garbage out of the way.
The pad with the engine/application/etc stamp is right above the right water pump boss. It's pretty small, and hard to see unless you move that a/c compressor and probably the bracketry out of the way. On the earlier cars you can just pull the alternator and there it is. Earlier SBC's have a larger pad so its easier to find.
Old Sep 8, 2003 | 12:25 PM
Vader's Avatar
The detail numbers are here:
If you don't need all that, the basic casting number is on the opposite corner:
Old Sep 8, 2003 | 12:34 PM
Water pump? The water pump is in the center of the engine. Does that mean I need to remove the TPI intake to see the tag directly BELOW the TPI body?
Old Sep 8, 2003 | 05:06 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Okay, now I know what you are looking for...I forgot about those numbers...
My new engine doesn't have that anymore, it was milled flat...At least I know the year of the block, that's really all I need to know...
Old Sep 8, 2003 | 08:49 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
k see there you have the c23 on your valve cover? ok now go an inch forward of that and about 5 inches to your right and thats where the ledge should be.. you defently have stuff in the way tho....
db057
Jan 10, 2020 08:55 PM
1992Z28!
Nov 19, 2015 07:33 AM
Giocio
Oct 1, 2015 12:20 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
ironbmt
Sep 27, 2015 06:00 AM
