Worth the extra money to get the CNC chamber option on Aluminum heads???
Old Sep 8, 2003 | 01:15 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
Just wondering if the CNC chamber option is worth it. I'll be getting a set of Trickflow 23 degree heads for my new 355 motor and was wondering if the 4 extra cfm on the intake and 9-10 extra cfm on the exhaust is really worth the extra $175.
The heads that will handle .520 of lift are $970, or $1,145 for the CNC version. If I step up to larger diameter valve springs, I'm in the price range of AFR's and would rather get those.
Old Sep 9, 2003 | 02:56 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Cmon''''''''''''
Geez guys!
Nobody has CNC aluminum heads??? I know a bunch of you guys are head wizards so let me know!!!!!
Old Sep 9, 2003 | 06:20 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
CNC macking is a computer making all chambers exactly the same. this will help to keep all the cylinders balanced. meaning having the exact same compression, swirl, burn pattern, etc.... it's like balancing and blueprinting a motor, not necessary. but, if you want maximum power you do it.
hand porting you may end up with one chamber at say 66cc and another one at 64cc and so on.
Old Oct 7, 2003 | 03:19 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Yippeee.....
I orderered these heads last night ( CNC ones), and I'm really excited about it. I also oredered the collest aftermarket valve covers ever!!!! well, that match my heads anyway. I also went with a ARP bolt kit as well. NO shortcuts here!!!!
Attached Thumbnails Worth the extra money to get the CNC chamber option on Aluminum heads???-tfs-31511802.jpg
Terrell351
Jun 13, 2021 01:13 PM
midge54
Dec 27, 2019 04:14 PM
Reddeath210
Oct 6, 2015 08:20 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
