shuddering car
Old Nov 13, 2000 | 09:09 PM
Snapcase19's Avatar
shuddering car
My car shudders when I let off the gas and coast. It doesn't the worst in drive and the other two gears. It does it very little when in overdrive. The tranny has been rebuilt and I'm pretty sure it isn't engine related. It feels as if something is pulling on the back of the car. If I hit the gas after coasting awhile there is a strong jerk before the car starts to move forward. Any Ideas?
1984 Z28 Camaro
350 crate motor
Edelbrock PerformerIntake
Edelbrock TES Headers
Hooker 3" Catback
ASP Pullies
Corvette Servo
JBL 150watt Amp
JL Audio 12" sub
Old Nov 13, 2000 | 09:27 PM
mtx28's Avatar
check motor/tranny mounts, my brother in law's 68 firebird shudders bad, i mean BAD, in reverse, but not forward, its a broken motor mount
Old Nov 13, 2000 | 09:30 PM
Snapcase19's Avatar
I know it isn't any of the mounts because they have all been replaced within the last year.
1984 Z28 Camaro
350 crate motor
Hooker 3" Catback
ASP Pullies
Corvette Servo
JBL 150watt Amp
JL Audio 12" sub
Old Nov 13, 2000 | 09:55 PM
Vader's Avatar
Snap,
MTX is in the right area. Take a look at the 'U' joints. While you're under the car inspecting the rear joint, check for free play at the pinion shaft on the axle housing. You should also check rear wheel bearings, LCA and torque arm mounting bushings, and don't forget to check the driveshaft for straightness.
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
Old Nov 13, 2000 | 10:26 PM
Snapcase19's Avatar
How do I know if the u-joints are bad?
1984 Z28 Camaro
350 crate motor
Hooker 3" Catback
ASP Pullies
Corvette Servo
JBL 150watt Amp
JL Audio 12" sub
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
novaderrik
Aug 10, 2015 12:44 PM
bryan623
Aug 10, 2015 11:33 AM
