Engine is missing from about 2500rpm on. Coil going bad already?
Old Sep 10, 2003 | 06:14 PM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
I thought it was a fuel problem at first, but there seems to be plenty of power and the engine doesn't start to sputter and die under load, just misses. The engine just starts missing when it is under load(accelerating) at around 2500 to 3000 rpms. I have an accel performance HEI distributor, about 2 years old. New plugs and wires and timing is set correctly. Cap and rotor is good to. Anyone have any ideas. Only about 7,000 mi on the engine and usually runs excellent. Still idles good to.
Old Sep 10, 2003 | 09:11 PM
TA5LiterHO's Avatar
Anyone had this problem with their HEI?
Old Sep 11, 2003 | 07:43 PM
Vader's Avatar
What coil are you using? What kind of plugs and at what gap? Have you tested the resistance of the ignition wires?
Old Sep 11, 2003 | 09:42 PM
TA5LiterHO's Avatar
Whatever coil comes with an Accel HEI distributor. Vaccum advance. Used to rev to 6500 no problem. Turn key once and fire up. I use ACDelco Rapid Fire Plugs .42 gap (which works fine usually, 8mm accell spiral core wires, new accel cap and rotor.
Old Sep 11, 2003 | 09:44 PM
TA5LiterHO's Avatar
have not tested any resistance. I did swap in a cheapie discount autoparts hei coil to see what happened. ran like s@#$. Thought it was fuel starvation/air in the fuel lines at first, but seems ok on fuel now. Pressure gauge broke the other day. Carb has no problems.
Old Sep 11, 2003 | 11:38 PM
TA5LiterHO's Avatar
Anyone else have any ideas? This is the first time I have been kinda stumped. hehe
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
86IROC112
Apr 9, 2016 10:20 PM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
