WHAT DOES THIS HURT??
lately to get the tires to smoke(like real smokey) In my t5, i put it in reverse, let it roll then put it in first (with the clutch in) and then drop it at like 1800. I know its not good but other than the tires, jolting the drivetrain and stuff, does it hurt the clutch anymore than a normal burnout????
86 IROC LG4,DUAL SNORKEL,AMERICAN THUNDER,3.27 GEARS
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
yea!, thats real bad for your car!!i can't blame you though I was the same way when I was 17(first f-body) I was the unofficial smoke show king,regretfully my car sucks now. don't do it anymore,get line cut-off valves for the rear brakes,get them installed proffesionally with valve control within drivers reach.it can be tricky with a standard,but you can do some real bad A$$ smoke shows with little harm done,and change gears to relieve the engine(keep RPMs low) rember: you need four brakes to stop so unlock your lines when the cops chase you away!!
Car: Death Mobile
Engine: 666 c.i.
When is the last time you tuned up your car? The other possibility is that your engine may be getting a little tired. Does it puff any blue while you are driving?
