Hooking up injectors on 87 TPI camaro, all injector wires same, Which goes to where?
Old Nov 14, 2000 | 05:57 PM
Wayquick4u's Avatar
im plugging the injectors back in on my 87 camaro i just converted from a 305 tpi to a 350 and all the injectors are like black with a pink stripe and look the same. Which goes where? someone tried to tell me the computer fires a whole bank of injectors at same time ?? that sounds very inefficient
Old Nov 14, 2000 | 06:51 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yes, the computer fires 4 injectors at a time. This system is called "batch-fire". There are 4 injectors on each side, and they should be laid out in a 2x2 pattern. Two in the front and two in the back, on each side. As long as you keep the sides correct (meaning left side from right side), you can hook them up whereever they line up.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Nov 14, 2000 | 07:37 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
The ECM fires all 8 injectors at the same time. It makes no differance which plug goes where.
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Heads, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine belt setup, Dual IROC Fans.
http://www.sethirdgen.org/octride.htm
Old Nov 14, 2000 | 11:51 PM
evilho7810's Avatar
No the computer only fires 4 at a time it's a batch fire system. They were pretty easy to figure out on mine. They only reach so far so just hook them to where the wires reach.
midge54
Dec 27, 2019 04:14 PM
Jae992
Aug 27, 2015 09:07 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
stalkier
Aug 7, 2015 04:49 AM
