Smog pump delete pulley now available...
Old Nov 14, 2000 | 01:17 PM
Dana92RS's Avatar
Some of you might have seen the recent magazine article (Nov '00 HotRod I think) that had the yellow '92 RS with the RamJet 350 installed. It also had a pulley where the smog pump normally is. Someone on the thirdgen mailing list just got one and said it bolts right up, I just ordered one (p/n 10186167, costs about $40) and should have it in a week. If you have or want to remove your smog pump but don't want to reroute your serpantine belt (as described in the tech article), you can install the pulley in it's place and have a nice OEM look, not to mention use the stock size belt. Anyways, just getting the info out...
Old Nov 14, 2000 | 09:07 PM
Scott 88 GTA's Avatar
Car: 88 GTA
Engine: modified L98
Axle/Gears: 3.27 9-bolt
Thanks Dana.
Also, when is the next SWMG going to be? I'd like to try and make the next one.
Black 88 GTA L98
New engine is in!
ZZ4 bottom end, Edelbrock 6085 heads, LT4 HOT cam, GMPP 1.6 RR's, ported stock TPI, SLP 1 3/4" headers, no cat, Dynomax cat-back
E.T.F.A Member #11
Old Nov 15, 2000 | 08:43 AM
Dana92RS's Avatar
Hey Scott - I dunno when the next SWMG is. I would think at the next swap meet which I think is in either March or April, I'll have to check with Gregg or Frank about it.
Old Nov 15, 2000 | 09:06 AM
Car: 88 GTA
Ok, whenever a date finally gets set for one let me know.
evilstuie
Jan 9, 2020 08:29 PM
italiano67
Dec 11, 2016 09:21 AM
LittleFranks
Sep 17, 2015 12:22 PM
BlackphantomZ28
Aug 21, 2015 07:12 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
