cant get her to start
Old Sep 12, 2003 | 09:02 AM
matts90firebird's Avatar
ok guys heres my build so far
i picked up a rebuilt 350 from a 69 ss elcamino
my guess is about 375hp-400hp (afterdriving it in the elcamino)
i droped in the motor and put some extra goodies on it
(poly mounts, chrome valve covers etc check out my site in my sig)
but never the less i cant get it to start
i know the motor works but i cant get her to run now
she never ran im my car but i did drive it b4 i droped her in
im starting to hit the end of my rope with gettin pissed on because im 19 and most places around here dont take me serious when i go to them.....ie. BBC in linden NJ, if your not 40 with a 73 or earlier muscle car he does not want anything to do with you..... so im sortof stuck on my own
**** ill even pay one of u guys if u can fix my **** up
the motor is completly in and bolted up the fuel lines are hooked up and all the electric stuff is hooked up
i think its the timing but i dont know for sure
the engine makes a wierd grinding sound when i try to start it
please help I live in Elizabeth NJ 07208
thanks guys
PS sorry about the long post
PS2 if you live local u can see her at goodyear on RT22 in union nj
thanks
Old Sep 12, 2003 | 10:05 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The distributor is probably in backwards.
Find the #1 compression stroke, by having somabody bump the engine slowly with the starter while you put your thumb over the #1 spak plug hole; then as soon as you feel compression, turn the engine until the #1 piston comes to the top. Look at the rotor. You'll probably find that it's pointed to the #6 plug wire.
The grinding noise is either the wrong starter, or The Starter Problem with the block. What did the starter sound like when the motor was in the El Camino?
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
