ECM differences for V6/V8?
Is there any difference between the ECMs used for a '84 Firebird with V6 and that with a V8? I would think they'd be the same except for the PROM, but I'm not sure. Can anyone clue me in on this?
Thanks...
Original owner - '84 T/A w/stock 305HO 5-speed
Thanks...
That and they've got different wiring harnesses.
94 Firebird Formula M6- No options but Z rated tires. No mods over $10. 13.5@105.
79 Malibu "beater" w/junkyard 400 SBC, tweaked QJet 4bbl, finally a decent set of heads, a few other tricks. A maddening 13.000001 @ 108 on the motor with little traction. No nitrous runs with the new heads yet.
Grandma's old 78 Malibu (33K miles!) soon to have the powertrain from the 79 put in it.
"One of the last remaining QJet tuners on Planet Earth!"
[This message has been edited by David Trimble (edited November 15, 2000).]
Car: 1986 Firebird
Engine: 2.8 V6
The 82-84 ECM's used a different connector for the harness than 85-up units. 82-84 was a "card-edge", 85-up was a regular pin connector.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Car: 1986 Firebird
Engine: 2.8 V6
Wouldn't there be a part # on the ECM? On a big sticker? I've always wondered this myself; it seems that the wiring diagrams (at least for the '86 models V6 vs V8) are very similar to the computer.
The PROM-Burning guys might know! (Let us know too!
There are computers that are used in GM 4 cylinder, V6 and V8 cars that have the same part number for the computer but different PROMs, but I can't remember what the part number is to save my life and what years they are.
ahhh, found it! I was thinking about the 90-92 computers to be used on a 90-92 TPI motor. Here it is even though it's not the year you are looking for but if they did it in 90-92 maybe they did the same thing in previous years.
GM P/N 01227730 from any 90-92 MULTI-PORT 4,6 or 8cyl. Cars. They are found in the Corsica's, Berreta's, Calais's, Cavalier
Z-24's and so on.....and of course the Camaro/Firebird but the others are in case you can't find a f-body to yank the computer from.
1988 TA 300+hp 350 w/ TBI and Holley TB unit, Holley projection intake,
WC T-5, 3.42 gears w/ Auburn posi. MSD 6A, edelbrock TES headers, dynomax 3" cat and cat-back system, ACCEL coil, polyurethane bushings all around, aluminum driveshaft, Mr. Gasket open air cleaner.
1993 S-10 w/ 4.3L V6 TBI, slightly bigger cam, Mild polish job and 3 angle valve job on heads, Edlebrock TES headers, Dynomax cat back, MSD 6A, ADS chip
2000 Kawasaki KX 125
