Cylinder honing?
Old Sep 12, 2003 | 07:19 PM
PaveTim's Avatar
Car: 1991 Z-28
Engine: 350 SBC
Transmission: Probuilt 700R-4
Cylinder honing?
I rebuilt my motor about 3000 miles ago and i put in total seal gapless rings. But the walls looked good so i did not hone them. Not even thinking about breaking the glaze the rings did not seat and it burns quite a bit of oil.. My question is if i take them out and do a hone job just enough to break the glaze would the rings that are in there seat properly or do I have to do new rings again. Thanks.
Old Sep 12, 2003 | 09:48 PM
Vader's Avatar
Well, since you obviously cannot measure gap and wear, you have no real idea of their condition. If you get them removed, inspect the profile of the rings to see if any of the original chamfer is left. The oil rails might be your best wear indicator.
If the rings appear to be in good condition and have tension, use them again. You might also consider using a really low-grade mineral oil to help the rings seat, like Quaker State or Pennzoil. Actually, a non-detergent, single viscosity like a 10W or 15W might help them seat it you take it through the normal ring seating procedure again.
If you've already done that, you'll probably need to get the bottle brush out...
Old Sep 13, 2003 | 06:51 AM
ede's Avatar
ede
i suspose you could and i know you'd want to save a few dollars, but i don't think i'd even consider reusing any rings, bearings, or seals. since you thought the holes looked good i'd guess you used a calibrated eye to do your clearance checks with too. the lack of honeing may not be the problem, or only a part of the problem.
FormulasOnly
Jul 23, 2018 08:47 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
