Broke my thingy that does that thing with that other thing
Old Nov 15, 2000 | 12:00 PM
1989CamaroRs's Avatar
i dont know the name of it, but i broke the nipple off of the 3 way junction of coolant hose that is right above my passenger side valve cover that i belive comes from the heater core. Anyway my question is, does coolant flow through there when the heater is not turned on?
Edelbrock TES Headers, High Flow Cat, Edelbrock Catback, SSM Subframe Connectors
Old Nov 15, 2000 | 12:07 PM
Birmass's Avatar
It depends on which nipple you broke. The three way thingy is a valve that is shifted as to whether you have the heat on. One of the nipples always has coolant flow. If you have the heat on it lets the coolant flow through the heater core. If the heat is off it bypasses the heater core.
88 firebird formula
350 Vortec TBI
214int/224exh, .471int/.491exh
Edelbrock headers
SIX-speed
Eats LS1's with a 2.73 open rear and 2 1/4 stock catback
My Formula
Old Nov 15, 2000 | 01:26 PM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
i beleive he is correct. it is called a heater by pass valve...i think. 20 bucks at the auto parts store....i broke one too.
Rick
90 Camaro RS 305 TBI
400 small block, Hooker 1 3/4 super comp long tubes, Random Tech Cat, Hooker aero chamber cat back on the way!!
TH700-R4 with Trans-Go shift kit
MacEwen Motorsports White Gauge Overlays
K&N Filter Charger (wooohooo)
GTS Headlight and Taillight covers
5% Limo Tint all around
Classic White Chevy Bowtie sticker on rear window
Man if my camaro were a rice-rocket all those mods would give me what...easily 50-60 hp!!!
Old Nov 15, 2000 | 05:52 PM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
Yeah, its the heater bypass valve. I picked one up at a junkyard for 5.00. I would just buy it from a junkyard. The nipple is the only part that fails on those valves anyways. When you go to get it though, slit the hose with a knife first, so you don't break the new one...
Clean it out really well, and install it...
c-ya
-=-Mike
1989 RS.. Newly installed 350,bored out 30 over, Hypereutectic pistons, double roller cam, double roller timing chain, accel wires, blue streak cap and rotor, rapidfire plugs, chevy caprice 350 chip, 200* fan switch.
Out-Cast
Sep 3, 2015 09:05 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ZZ42Fast
Aug 30, 2015 02:39 PM
Jae992
Aug 27, 2015 09:07 AM
Bob88GTA
Aug 18, 2015 03:31 PM
