code 54 gone, gremlin still lives on!
Old Sep 14, 2003 | 12:34 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Here's what I'm working with. 88 Formula, Lo3, Tbi, EST Ign. Only Mod's are 3" cat back and smaller air filter lid to create open elem. 4* adv. on Init. timing. The problem: car starts, warms up, run's like crazy, can't hold it back. But, when you get where your going (10 mi. or a hundred) and shut it off (for 5min or five hours) and start it again, it goes to fast idle slows down, surges, and dies! and that leaves me 2 opptions: continue to restart it 2-4 times untill it finally stay's running or, when I start it the second time, push the pedal down about 3/4 and let everyone within ear shot hear it sputter miss and rev up 2500 rpm untill it smothes out (about 5-10 sec) and then it idle's ok. In both cases after restart the performance is down like there is no Ign. adv. going on. the bottom end power is good till about 3000 rpm and the nothing. Might as well be in neutral. seems to be getting worse lately. as I write this I've realized I recently switched to 87 Oc. gas from Prem. and could be agrivating the problem. I'm going to switch back to prem. and see if it will improve a little. It might be a knock sen. spark cont. sys. problem, but I still don't get any codes. any help with idea's on what to look for will help I hope . I've allready done all the basic checks and everything look's Ok or has been replaced. Thanks !
Old Sep 14, 2003 | 01:34 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Transmission: ZF 6 speed
Axle/Gears: Dana 44 3,33
My car did something like that last winter. I decided to start the car after leaving it in the garage for 5 weeks then hell started. When it got hot the engine did like your engine does, it did this all winter . I think i had moisture in the distributor or water in the gasoline. It was gone when spring arrived and the snow was gone. So remove the distributor cap and have a look. When the engine get hot the water turn into steam. I guess your problem only appear when the engine is hot.
Old Sep 14, 2003 | 02:10 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Nope! opened it up and it's clean and dry. I noticed your a trucker! I am too. I run the eastern U.S. about 2500 mi. -3000 a week. I only drive the car on weekends if I do, and don't spend a lot of my time off working on the car. So, this has been a long time problem that won't seem to show it's self like a man! I think the car was built by a woman!!
Old Sep 15, 2003 | 10:56 AM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Yeah im also a trucker but i run the eastern Sweden about the same distance in my Volvo truck.
Sorry i couldnt help you.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
Agent507943
Camaros Wanted
Oct 2, 2015 07:17 AM
dusterbd
Sep 29, 2015 08:40 AM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
