block heater question
Old Nov 15, 2000 | 03:20 PM
ihateallmustangs's Avatar
are they worth the money?[it goes down to -35c here] and do they just keep the oil warm? thanks.
Old Nov 15, 2000 | 08:30 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Worth the money??? I'm from Canada and have never seen a car without one. I use Mobil 1 oil and don't plug in until it goes below -20C. All the block heater does is heats the coolent which will keep the engine warm. The car will start easier with a warmer engine. It's less wear and tear on all the internal parts as well as the starter and battery.
The oil will still be reasonably cold but will gather some heat that's transfered by the oil pan.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
454 Big Block buildup now in progress for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car
91 454SS daily driver
95 Homebuilt Harley
Old Nov 16, 2000 | 08:55 AM
ok then. i guess i will invest in one. thanks
Frozer!!!
Jan 19, 2024 04:55 PM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
lakeffect2
Aug 23, 2015 08:44 AM
redmaroz
Aug 16, 2015 11:40 PM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
