torque converter like a clutch
Old Sep 14, 2003 | 06:54 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
alright, i dont know if you know what the subject meant but i'll explain. I was told for all you people with an Automatic Trans and like to drag there is a way to get off the line like a manual. There is a certain torque converter that can disengage and then engage like a clutch, even at high RPMs. I would like to know if anyone else has heard of this and/or used one.
i like to drag but am tired of having to start off the line at low RPMs due to an Automatic Trans.
Old Sep 14, 2003 | 07:05 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
well by upping the stall of the converter it acts like a clutch dump in a way... so if you have a 3500 rpm stall converter... when you stomp the gas it will flash to that rpm and in a scence "act like a manual tranny" clutch dump
Old Sep 14, 2003 | 07:14 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
nah, thats not what i was talking about. But you've made me think, is there a way to add a clutch to an automatic trans. Like just after the driveshaft to the axle starts. Only needing to be disengaged when dragging or other such reasons. That would actually be kinda cool wouldn't it?
Old Sep 14, 2003 | 07:22 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
There's probably a 15K option that will allow you to do what you want, but in the most part, a stall convertor and if you have a few more bucks a transbrake, is the way to go.
Old Sep 14, 2003 | 07:24 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
why would u want that???
what exactly are you looking for out of your question... there are clutches in side the TC that are used for LockUp purposes of overdrive... so the converter doesn't slip at all time and it becomes locked in w/ the driveshaft...
Old Sep 14, 2003 | 07:32 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
Bingo! I have no personal experience with them but id be willing to bet from how theyve been described that a trans brake is EXACTLY what youre looking for
Old Sep 14, 2003 | 07:45 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
ok and it wont screw up anything doing it? and also how would i go about installing one, and how much would this cost?
Vassago
Convertibles
Sep 4, 2015 09:37 PM
jtwoods4
Sep 3, 2015 05:39 PM
tonys91rs
Sep 2, 2015 07:07 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
