HAD THIS PROBLEM FOR OVER A YEAR
Old Nov 16, 2000 | 03:12 AM
92b4c's Avatar
I HAVE LOUD TAPPING NOISE CUMMING FROM THE BACK PASSENGER SIDE OF THE MOTOR. AT FIRST I FIGURED A LIFTER BUT THEN I NOTICED IT ONLY STARTED TAPPING AT CERTAIN TIMES LIKE ONLY WHEN THE ENGINR IS WARM, AND ONLY ABOVE 2000 RPM WHEN THE THROTTLE IS STATIONARY. IF I LET OFF THE GAS IT STOPS IF I PUNCH IT IT STOPS. BUT UNLESS IM FLOORING IT OR STOPING, IT MAKES THE NOISE. AND IT ONLY DOES IT IN GEAR BUT IT CANT BE THE TRANSMISSION BECAUSE IT HAS BEEN REBUILT TWICE (FOR OTHER REASONS) BUT THE TAPPING IS STILL THERE
92 b4c 305 t-5
ported plenum
58mm TB
dynomax headers
msd coil
adjustable fuel regulator
air foil
K&N
TB coolant bypass
smog pump bypass
worldclass t-5
custom built y pipe
hi-flow cats
flowmaster
hurst shifter
3.73 rear
Old Nov 16, 2000 | 10:29 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
PLEASE DON'T SHOUT!!!! Everybody can still hear you if you talk in a normal tone of voice, like this. All-caps is extremely hard to read.
Your problem sounds like a cracked flex plate to me.
Old Nov 16, 2000 | 01:54 PM
92b4c's Avatar
its a five speed and the flywheel has been resurfaced twice
92 b4c 305 t-5
ported plenum
58mm TB
dynomax headers
msd coil
air foil
K&N
TB coolant bypass
smog pump bypass
worldclass t-5
custom built y pipe
hi-flow cats
flowmaster
hurst shifter
3.73 rear
Ghettobird52
Jul 5, 2024 11:18 PM
Cleotiz
Jan 6, 2018 08:56 PM
neekolzun
Aug 24, 2015 04:59 PM
Bryan F
Aug 18, 2015 02:28 PM
Fronzizzle
Aug 9, 2015 01:15 PM
