Rough Idle/Car Dies
Old Sep 14, 2003 | 09:31 PM
JediNemesis's Avatar
Rough Idle/Car Dies
My 89' RS 305 TBI occasionally dies at idle or at a couple thousand rpms after initially accelerating. While idling, the idle speed varies about 100-200 rpms every 3-5 seconds. On the low side its at about 550 rpms, and it feels like its about to die (sometimes it does). I recently replaced the fuel filter, and I tried adjusting the timing to no avail (yes, I disconnected the wire). I would appreciate any ideas you guys might have.
Thanx alot,
Will
Old Sep 15, 2003 | 01:55 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
Check your cap and rotor. If you see no sign of wear or a broken rotor, check your spark plugs. If you see no sign of fouling or serious corrosion, check your spark plug wires. Look along the block (especially at the back of the exhaust manifolds) and look for black or white dusty marks on the engine block or manifolds.
After all of this, check your injectors.
Good luck
Old Sep 15, 2003 | 03:00 PM
lykan's Avatar
I concur after plugs,wires,filters.. and injectors. Then test the EGR theres a good how to thread running around here on the EGR. It what was causing my idle problems.
Old Sep 15, 2003 | 03:27 PM
dutch89gta's Avatar
Was wondering about it too. My car does this when it's cold. The idle speed goes up to 1500 then back to 500 then back to 1400 or so for quite a while until it's hot. Then it run's pretty fine. I am gonna put in some new plugs and oil anyway because the car has stood for the last 4 years before I bought it.
Gunner242
Dec 25, 2015 04:49 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
Luigytico09
Oct 1, 2015 08:46 AM
Jlanz55
Sep 29, 2015 08:55 AM
