L98 Heads Fit Stock 305? Too Much?
Old Sep 15, 2003 | 12:20 AM
Trevor K's Avatar
Are L98 heads too much for a carb'ed 305 (LG4)? And are ported/polished L98 heads a good fit for most engines (Under 350HP)?
Old Sep 15, 2003 | 12:35 AM
Trevor K's Avatar
Oh - and I have centerbolt valve covers so I assume they bolt right up?
Old Sep 15, 2003 | 01:31 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
L-98 heads are not "too much" or a 305.
Cast iron L-98 heads will drop the compression ratio of a stock
305 a little. The combustion chamber size is larger 64cc VS 58cc's They could be milled to 58cc's to maintain the cr if you want.
The aluminum L-98 heads have the same 58cc combustion chambers as stock 305 heads.
Either will work well on a 305 with their larger valves especially with a little porting.
Azrael91966669
25
Jun 20, 2017 04:04 AM
CRFred
Feb 7, 2016 11:39 PM
matthew911
Aug 12, 2015 09:38 AM
marcusaw
Aug 10, 2015 08:13 AM
Leggman1
Aug 6, 2015 04:15 AM
