Remote Starter Solenoid starting problem!
Old Sep 15, 2003 | 09:45 AM
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
Transmission: T-56, Viper output shaft
Axle/Gears: Strage 12-bolt 3.73:1
I just installed the remote starter solenoid as outlined in the tech section. The car starts up every time; however, the starter motor doesn't disengage until about 2-3 seconds after the car has started. What I hear is the typical high pitched metal on metal/gear on gear sound.
Any ideas, suggestions?
Oh, just to note: I have the lifetime guarantee starter from O'rielly's so when I pulled my old starter out, I exchanged it for a new-rebuilt one. Possibly could it be the starter or the new remote solenoid??
Old Sep 15, 2003 | 10:45 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Shouldn't this be in the Electronics board?
A lot of remote starter have either a timed solenoid, or an RPM switch, either of which you can choose.
I would find out if yours has an RPM switch and hook it up. Most of them release the starter after the RPMs have reached ~400.
Old Sep 15, 2003 | 11:59 AM
Neil's Avatar
Car: '87+'02 Z28
Engine: 454 LSX
From what I can see there is not an adjustable RPM switch on this solenoid. If it's timed how can that be changed or can I get another solenoid with different timing? The solenoid I have is a Borg Warner part that is supposedly equivalent to the Wells solenoid F496 used in the tech article.
Old Sep 15, 2003 | 12:12 PM
AJ_92RS's Avatar
I just realized you're talking about doing this.
Never mind. I though by "remote start" you meant the ones you can start your car from inside the house to warm the car up.
I stewpid
From what you're experiencing, I'd look at replacing the solenoid. It sounds as though it's staying closed longer than it should be.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
92camaroJoe
Aug 13, 2015 06:07 AM
