car running to cool
Old Nov 16, 2000 | 01:58 PM
bad@ss92camaro's Avatar
car running to cool
i just rebuilt my engine and before i rebuilt it it was hard to keep it cool it was the summer time then ,and now that i rebuilt it its starting to get a little cold and my car hardley ever gets warm. if its around 40 degrees outside i can drive to work (30 minute drive) with no fan and be lucky if i get 110 degrees just put a new thermastat in it and does the same thing and the gauge has to be working cuz one day i got home after driving around awhile with no fan i popped off my cap and the water was just starting to get warm
92 camaro 25th anniversarry polo green with 2 gold stripes stock 305 tbi
89 camaro
white
92 ground effects
cowl induction hood
tinted windows
accell plug wires
K@N filter
305 from 92 camaro
carburated
bored .030
flat top pistons
larger valves
zz4 cam
heads shaved
Old Nov 16, 2000 | 09:28 PM
92b4c's Avatar
im notsure what the problem is you might want to use a higher degree thermostat like 180 or 195 but consider yourself blessed i wish i could get mine under 200
92 b4c 305 t-5
ported plenum
58mm TB
dynomax headers
msd coil
adjustable fuel regulator
air foil
K&N
TB coolant bypass
smog pump bypass
worldclass t-5
custom built y pipe
hi-flow cats
flowmaster
hurst shifter
3.73 rear
Old Nov 16, 2000 | 10:07 PM
JJ's Avatar
JJ
weird, I'm having the same problem as you with a new carbed engine. I've put in two new thermostats with the same result. A 160 and 180. I worry about running the engine at such a low temp myself. I don't have heat either, which may be unrelated - this weekend I will have time to check things more thoroughly - hopefully.
Old Nov 16, 2000 | 11:28 PM
mikesegar's Avatar
Car: N/A
Engine: N/A
Transmission: N/A
Old Nov 17, 2000 | 07:51 AM
82camaro's Avatar
Car: 82 camaro SC
If the thermostat is working, the engine has to warm up because no coolant is flowing. Also, the radiator coolant temp is not going to be an accurate reading of the engine temp if it's cold outside and the thermostat is closed most of the time.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
TheExaminer
Aug 26, 2015 04:59 PM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
