engine lingo
Old Nov 17, 2000 | 04:46 AM
camaro84boy's Avatar
engine lingo
I just had some questions about engine words. like for example what is a liter, such as in 2.8 liters? And what is v6?-valves, right? but what are they and where are they located? And how would I find out how many barrels my car has, and cc's. I have a 1984 v6 2.8 liter camaro. I just wanted to know more about my car. I am a beginner, so bare with me. and thanks.
Old Nov 17, 2000 | 08:27 AM
Yarnboy's Avatar
A litre and liter are just another way to measure displacement. When you hear the term 5-0 refering to a Mustang, it is an engine that has 302 cubic inches. When refering to a Camaro, it is 305. V six means the engine's block is in a V design. The cylinders are slanted sideways. 3 on the right of the eninge, three on the left. Like a V if you were looking at it head on. V 8 has four cylinders on each side, 8 total. Am I making sense? Valves are located under the Valve cover aka the rocker arm cover. That is the shiney piece of metal you see in hotrods that says Corvette or has a bowtie on it and the rectangle one each side of your engine that has an Oil cap on the right side. Not sure about the barrels on your carb...4 maybe? Someone else will surely know that. Not many will fess up to this, but everyone was a begginer at somepoint..good luck with your car!
I can't type so I had to edit this..
-Red '88 IROC 5 Speed 305 TPI w/3.08
-Dual Friction Centerforce Clutch
-Accel 300+ Racing Ignition
-Accel 300+ Pro Sleeve Plug Wires
-Accel U-Groove Plugs
-Flowmaster Force II 3 Chamber Cat Back Exhaust
-Hypertech Chip
-Hypertech Airfoil
-Removed, Then Re-installed (out of fear) MAF Screens
-Gutted Air Box
-Best E/T 14.90, 60 ft. 2.17, 1/8th mile 9.61(bald tires, Code's 34,36)
-Best MPH 92.7(bald tires)
[This message has been edited by Yarnboy (edited November 17, 2000).]
Old Nov 17, 2000 | 08:34 AM
Yarnboy's Avatar
A litre and liter are just another way to measure displacement. When you hear the term 5-0 refering to a Mustang, it is an engine that has 302 cubic inches. When refering to a Camaro, it was 305. V six means the engine's block is in a V design. The cylinders are slanted sideways. 3 on the right of the eninge, three on the left. Like a V if you were looking at it head on. V 8 has four cylinders on each side, 8 total. Am I making sense? Valves are located on the Valve cover aka the rocker arm cover. That is the shiney piece of metal in hotrod's and the rectangle one each side of your engine that has an Oil cap on the right side. Not sure about the barrels on your carb...4 maybe? Someone else will surely know that. Not many will fess up to this, but everyone was a begginer at somepoint..good luck with your car!
-Hypertech Chip
-Hypertech Airfoil
-Gutted Air Box
Old Nov 17, 2000 | 08:38 AM
MikeS's Avatar
Your '84 2.8L V6 has a two barrel carb. Looks like the rest has been taken care of already.
Mike
Old Nov 17, 2000 | 08:54 AM
MikeS's Avatar
oh yeah, I forgot about the cc's. I assume that you mean engine size or displacement. The engine in your car is 2800 cubic centimeters (173 cubic inches).
Old Nov 17, 2000 | 08:55 AM
MikeS's Avatar
Mike
84z96L31vortec
Aug 20, 2017 12:16 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
