park/nutral switch
Old Sep 16, 2003 | 08:45 PM
TOM305T/A's Avatar
Car: 1987 GTA 350 auto
park/nutral switch
can you tell me where this is at?and where the starter relay is. thanks
Old Sep 16, 2003 | 09:34 PM
mikes92rs305's Avatar
im not sure about the starter relay but i can tell you where the neutral safety switch is. its located in ur center console hooked up to your shifter.
Old Sep 17, 2003 | 04:33 PM
demonchild's Avatar
its one of the easiest things to fix. its in the center consol to the right of the shifter. there is two screws that hold it down and are used for adjusting it. it has a little white tab going into the shifter and is shaped like this. they are like 20 dollars new at kragen. and has a connector on the front of it.
Attached Thumbnails park/nutral switch-untitled.jpg
Veaceonee
Sep 29, 2016 08:15 PM
RacerM
Sep 28, 2015 04:25 PM
tglennon11
Sep 23, 2015 05:30 PM
327IROC85
Sep 23, 2015 12:11 AM
Randomtask2
Sep 10, 2015 08:37 AM
