Throwing Flames From Exhaust..
Old Sep 16, 2003 | 10:35 PM
Stingraye's Avatar
Car: 1986 Trans Am
Engine: 350 W/Plenty of Mods
I was talkin to a bunch of guys in the shop at school the other day, and the teacher was sayin how they get the cars to shoot flames (like gone in 60 secs and stuff). And he said all they do is take a crappy like toyota coil or something, and drill a hole in your exhaust, thread in a general spark plug and wire it to the coil, and when u turn on the coil, the spark plug will ignite the left over fuel in the exhaust if it's running rich enough, and shoot flames. I have a straight pipe, so that would be a peice of cake to drill a hole, and the exhaust is pretty much free flowing, so nothing to burn up, and i've got a 700 mech holley on a 305 (350 blew), so I know it's running rich, so do you guys think this would work or what?? I think that would be sweet as anything to have my car really define "FIRE"bird. I'd have to figure out what the easiest way would be to set up a coil to do that, but what do you guys think about that setup? Thanks.
Old Sep 16, 2003 | 10:37 PM
pre's Avatar
pre
Car: 87 Firebird
Engine: 305 LG4
Transmission: THM700R4
They did this on the TNN show TRUCKS and set it up the same way you said it was pretty cool.
Old Sep 16, 2003 | 10:38 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
https://www.thirdgen.org/techbb2/sho...hreadid=191406
this is just one example of what you will find when searching through the exhaust section. give it a shot and you should find anything you need on this topic.
Old Sep 16, 2003 | 10:53 PM
Stingraye's Avatar
Car: 1986 Trans Am
would you be able to put the spark plug where my straight pipe is (where stock cat would be), or is that too far back and it has to be right at about the tips?? Just wondering.
Old Sep 16, 2003 | 11:31 PM
pre's Avatar
pre
Car: 87 Firebird
Engine: 305 LG4
You want it like a 1/2 foot from the end of the tips so you don't throw flames through the whole cat-back or in your case off road pipe back. I heard sending unburned gas through the engine is not to good and kills all internal lubrication.
Fanatic1074
Oct 3, 2022 05:57 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
2012sergen11
Oct 13, 2015 07:38 PM
racereese
Oct 3, 2015 03:46 PM
ndndndnd
Sep 28, 2015 08:00 AM
