Tips for removing flywheel
Old Sep 17, 2003 | 02:51 PM
PioneerCrazed's Avatar
Car: Mark VIII
Engine: 4.6L DOHC
Transmission: 4r70w
I just pulled my engine, and now need to remove the flywheel. Any tips, I tried having someone hold the crank bolt and I'll turn the flywheel bolts but that seemed to loosen the crankbolt.
Thanks for any help.
BTW I'm doing this to replace the freeze plugs.
Old Sep 17, 2003 | 03:09 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Flywheel or flexplate?
Stick a large screwdriver or prybar through a hole in the flexplate, jam it up against the block as you turn the bolt in the loosening direction.
For flywheel, put a bolt in a bellhousing mount hole, use a large screwdriver in a starter tooth jammed against the bolt.
Old Sep 17, 2003 | 03:44 PM
Car: Mark VIII
Engine: 4.6L DOHC
Transmission: 4r70w
Alright, thanks I got it...
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Stangski09
Nov 14, 2015 01:27 PM
Jlanz55
Sep 6, 2015 07:28 PM
