will tpi choke a 400?
Old Sep 18, 2003 | 12:47 PM
91dubZ28's Avatar
Car: 1991 Z28
Transmission: WCT-5
I want to start building a new motor for the 'maro, I want to go with a 400 small block, I was just wondering if a stop tpi set up would choke it? Is anyone running this set up? what were the results?
Old Sep 18, 2003 | 01:13 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
YES! it will choke it.
its choking the stock 305 at high rpm.... it can bearly handle the 350.... it would really make you loose alot of that 400s potential.
what would happen? well off the line, you would have the great 400 TQ and the TPI helping you.... right up until it maxxes out on air... probly around 2500rpm... lol
and if you build your 400 for nice high rpm power, then it would be even worse.
keep the TPI injection, but get a diff manifold. like the LT1 conversion or the stealth ram.. dont even bother with the modded tune port type. they still restrict breathing, and they cost too much...
Old Sep 18, 2003 | 05:15 PM
83 Z28 HO's Avatar
Car: 83 z28
Engine: L69
Transmission: BW t-5
Stealth ram is a very excellent setup, I would go with it.
Old Sep 18, 2003 | 09:10 PM
Vader's Avatar
Well, depending on the VE of the 400, it may not choke it until you reach about 3,500 RPM.
Ported LT1 intake, anyone? The GMPP Ramjet 502 makes 510 HP through the 48mm TB, so don't even go there...
Old Sep 18, 2003 | 11:59 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
true... but just a example..
i never have gone there, lol... i still dont know why people buy the huge TBs when they have a mostly stock engine.. *shrug*
Old Sep 19, 2003 | 09:47 AM
91dubZ28's Avatar
Car: 1991 Z28
Transmission: WCT-5
i still dont know why people buy the huge TBs when they have a mostly stock engine.. *shrug* [/B]
yeah i dont undersatnd that either, they are so expensive too,.
Old Sep 19, 2003 | 10:09 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Mental Horsepower
For the same reason they put an 850 DP Holley on their stock 305, cause they saw it on some guys car at the track that runs 10's.
Old Sep 19, 2003 | 12:11 PM
prOject-IrOc's Avatar
Car: 1990 Iroc-Z
Re: Mental Horsepower
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
lakeffect2
Aug 23, 2015 08:44 AM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
