Need help please !! firebird is making a knocking sound!
Old Nov 18, 2000 | 03:53 PM
91camaroRS's Avatar
omg i started up my firebird today and soon as it started it knocked like crazy and if you hit the gas it gets louder. It is insanely loud. man that sucks can anyone here help me please ....?????
:confused
Old Nov 18, 2000 | 08:14 PM
91camaroRS's Avatar
come on somebody has to be able to help me out here...... please post..
thanks later
Tim
Old Nov 18, 2000 | 08:32 PM
DSouthern's Avatar
Hate to provide bad news but it could be a spun rod bearing. If the noise increases with engine speed, this is likely the problem. How many miles do you have on the engine? If you know a mechanic have him listen to the noise. You could also drain the engine oil and look for a bearing material (a silver looking metal) in the bottom of the drain pan. Also you can pour the oil from the oil filter and look for the same silver residue.
Old Nov 18, 2000 | 10:14 PM
91camaroRS's Avatar
100,000 just clocked over ..yes it does go with the speed of the engine ...how would i fix that ??
Old Nov 19, 2000 | 12:39 PM
DSouthern's Avatar
If you have a engine bearing problem you have to remove the crankshaft from the engine to fix it, which means you have to remove the engine from the car as well. If you want to keep the car, sounds like its time for an engine rebuilt.
jhawkeye
May 25, 2022 06:33 PM
Andrew6.688
Dec 13, 2015 10:59 AM
db057
Aug 22, 2015 08:17 PM
st.evel07
Aug 13, 2015 06:15 PM
gwade12
Aug 8, 2015 08:17 AM
