Slow Cranking
Old Sep 19, 2003 | 02:34 PM
Greasemonkey's Avatar
Car: 86 Cutlass
Transmission: 200-4R
Slow Cranking
I've been having some problems with slow cranking and was hoping you guys could help. The problem started after swapping on the LT1 intake. During the swap only the intake was changed. Now, the car won't even crank fast enough to fire off. The starter is a year old CVR unit, checks out fine. The grounds have been checked, all seem fine. The battery was changed out to a known good battery, no change. I'm using a remote solenoid that is also less than a year old. Any ideas on what the problem could be? Thanks.
Old Sep 19, 2003 | 02:48 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Lose the remote solenoid and see if it helps. You shouldn't need it with a quality starter on there rather than a Delco one.
Old Sep 19, 2003 | 03:11 PM
Car: 86 Cutlass
I put the remote solenoid on because the battery's in the trunk and was having some heat soak problems. I was planning to hook the battery back up in the front tomorrow though and see if that helped anything.
RedLeader289
May 28, 2019 01:47 PM
RS Reaper
Oct 17, 2018 07:52 PM
bjpotter
Oct 4, 2015 07:48 PM
Luigytico09
Oct 1, 2015 08:46 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
