car idles high and spits gas out the tail pipe??
Old Nov 19, 2000 | 03:24 PM
jons89Firebird's Avatar
i changed my spark plugs and wire and when i started the car again it makes a loud hissing sound and idles around 1200rpm and never idles down. After i turned off the car i noticed some gas right under the tailpipe. The only thing i removed was the air cleaner assembly and the connectors to it. It didn't do this before. What could it be? Thanks in advance.
Old Nov 19, 2000 | 04:44 PM
Birmass's Avatar
That loud hissing sound is either a vacuum leak or you knocked your IAC connector off. Both would cause high idles.
88 firebird formula
350 Vortec TBI
214int/224exh, .471int/.491exh
Edelbrock headers
SIX-speed
Eats LS1's with a 2.73 open rear and 2 1/4 stock catback
My Formula
Old Nov 19, 2000 | 07:54 PM
Corry's Avatar
Car: 1987 Trans Am
Axle/Gears: 10 Bolt SLP Torsen, 3.73 ratio
The hissing could also be caused by not tightening up the air intake assembly. Are you sure it is gas coming out the tailpipe? Sometimes, the car will drip other fluids out the tailpipe. What they are I do not know, but I am sure they are not gasoline. (probably just some water from super heating the air, and the cooling it as it goes through the exhaust system).
High idle...check that your IAC is functioning properly.
Corry
Azrael91966669
25
Jun 20, 2017 04:04 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
mustangman65_79
Sep 1, 2015 03:51 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
