Anyone Know the specs on the peanut cam in the 305TPI (lb9)
Old Nov 19, 2000 | 05:44 PM
Stell1579's Avatar
i tried searching couldnot find anything
-Stell
1988 IROC 305TPI MINT!!
Mods= Accell SuperCoil, MSD 6A, Ported Plenum, No MAF Screans , K & N, 160 Thermostat+ Temp Switch, Relocated MAT, Cold Air
Old Nov 19, 2000 | 06:12 PM
Jester's Avatar
I don;t recall exactly..but it's 17x/19x @.050 duration, .39x/.40x lift....and I think a 109LS.
Overall too crappy to be worth remembering.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
Jesters's Page of Sick Pleasure
Florida Thirdgenners Message Board
ICON Motorsports
Old Nov 19, 2000 | 09:42 PM
Vader's Avatar
Stell,
This is what I have for data:
1985 305 TPI 215 hp / 275 lb/ft Tach: yellow 5000 red 5500
Valve Lift: intake .404 exhaust .415
Lobe Lift: intake .269 exhaust .277
Duration: intake 294 (crank) exhaust 294
Duration at
.075 valve lift 202//206/
Overlap at
.075 valve lift 4/
Accel rate above
.075 valve lift .00553"/deg.
Lift at TDC .085"
1986 305 TPI 190 hp / 285 lb/ft Tach: yellow 4500 red 5000
SPECS ACTUAL
Valve Lift: intake .350 .360
exhaust .385 .388
Lobe Lift: intake .233 .236
exhaust .256 .258
Duration: intake 320/ 226/
(crank) exhaust 320/ 245/
Duration at
.075 valve lift 179//194/ 180//195/
Overlap at
.075 valve lift 4°
Accel rate above
.075 valve lift .00491"/deg.
Lift at TDC .085"
1986 305 TPI 1.6:1 ROCKERS 207 hp / 302 lb/ft Tach: yellow 4900 red 5400
SPECS ACTUAL
Lift: intake .374 .378
exhaust .412 .413
exhaust .256 .258
Duration: intake 320/ 320/
(crank) exhaust 320/ 320/
Duration at
.075 valve lift 187//202/ 191//203/
Overlap at
.075 valve lift 8° 9°
Accel rate above
.075 valve lift .00484"/deg
Lift at TDC .090"
Roller rockers - 1.6 intake x 1.5 exhaust will add 12.2 HP;
1.6 x 1.6 is worth another 4.4 HP;
Torque peak @3300 RPM, HP peak @ 4400RPM - Slight idle lope
TOTAL 17.4 more ft/lbs and 16.6 more HP
Later,
Vader
"Make Me Bad"
Adobe Acrobat Reader 4.0
[This message has been edited by Vader (edited November 19, 2000).]
Jorlain
Oct 8, 2015 01:57 AM
angel2794
Sep 8, 2015 06:22 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
86iroczwv
Sep 3, 2015 06:21 PM
masonta
Sep 1, 2015 06:40 PM
