these boards are the best!
Old Sep 21, 2003 | 11:15 AM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
these boards are the best! another ?
Finally got my 85 z running like a mean kitten, i was blowing fuses in the dash ran like a bag o you know what, wouldn't turn over at one point, needed to know how to change valve seals. You guys helped me with all of the problems.
Now i need a digital camera to find out what one last wire goes to. i will try to describe it is brown and black with water tight connectors has a short wire pluged into it with a stange looking pin config. they are real close almost like what a speaker conector looks like but smaller, two of them in connector. the wires come out of the main harness by distrubitor. could go on either side of engine from where it comes out.
now that the car runs what high fail parts should i replace while i'm under the hood, car has been sitting over a year. i was thinking about changing all sensors, water oil pressure nock ect. does this make any scence or are these part relaible?
Thanks Again you guys rock:hail: :hail: :hail:
oh ya the engine is a 305 tpi with auto blown trans soon to be t5
Elephantismo
Feb 13, 2019 12:51 AM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Linson
Oct 1, 2015 09:50 PM
zman1969
Oct 1, 2015 11:09 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
