Will 1.6 Self Align rockers fit under my Moroso Centerbold Covers?
Old Nov 19, 2000 | 04:50 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Old Nov 19, 2000 | 06:47 PM
ede's Avatar
ede
word from comp is their new 1318 rockers will fit under stock center bolt valve covers. i have a set ordered, if they ever start making them. i've heard alot of people here say they have to do minor trimming to make roller rockers fit. best to ask the maker if they'll fit.
-=ICON MOTORSPORTS=-
1st & 3rd
Old Nov 20, 2000 | 09:10 AM
sparks383iroc's Avatar
Car: Mullitt mobile :)
Engine: it's stock LOL
Transmission: 700rJunk
Axle/Gears: 2 much 4 street not enough for strip
Yes, I have them under mine. The only problem I have with them right now is the poly lock nuts. I have the Crane golds with ARP poly locks. The ARP nuts are a little taller the ones Crane shipped with the RRs and are keeping the valve covers from seating all the way. I would put the Crane poly locks back on, but I had a problem with them backing off. So now I'm going to grind some reliefs in the Moroso covers to accomodate the ARP polys.
Sparks a flyin'
1989 L98 IROCZ, Bored .030 over,400 Crank,Dart PRO 1 Heads 200cc intake,ZZ3/ZZ4 Cam,Crane 1.6 RR,Edelbrock 3860 Hiflo TPI Manifold, AS&M LTRs, Edelbrock 58MM TB, Ported Plenum, TCI Reverse Pat Man Valve Body, SVO 24# injectors,TCI Streetfight Stall Converter, 3.23 Gears on Auburn Pro Posi, Some Suspension Mods
midge54
Dec 27, 2019 04:14 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
happyhapka
Aug 15, 2015 04:42 PM
