smog & a/c removal ... what next
Old Sep 21, 2003 | 05:04 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
hey, my a/c doesnt work, and its R12.. i dont know how much it would cost to make it work properly.. but it takes a sh-tload of space.
And the smog stuff is also space consuming..
So to REMOVE, is it really straight forward ?
Once its removed.. what do I plug the holes with ?
Brass plugs? where to find ?
I have to keep an heating/air system.. but a/c.. no need.
thx in advance
Old Sep 21, 2003 | 08:26 PM
mikes92rs305's Avatar
as far as the condensor goes, just unbolt and yank the whole thing out (...careful cause there might be pressure in the system...). as far as the ac pulley and box, u can buy a AC delete pulley from gmparsdirect.com and a AC delete heater box that goes on the firewall.
Old Sep 21, 2003 | 09:09 PM
Spectre's Avatar
Engine: 3.0L/183
so I get delet pulley for the a/c, and delete box .
that seems simple.
Im gonna need a shorter belt..
the smog stuff, where can i fing plugs for the holes ?
I dont want to unplug everything then be stuck with holes ..
thx for the replie
Old Sep 21, 2003 | 09:41 PM
if u get the delete pulley, u may use the same size belt. any hardware store should have brass fittings to cap the ends of the tubes.
Old Sep 21, 2003 | 10:28 PM
Spectre's Avatar
Engine: 3.0L/183
cool, thanks
diana227vegas
Jul 8, 2016 12:27 AM
Victor6
Aug 30, 2015 02:09 AM
3rdgenparts
Aug 8, 2015 07:09 PM
mustangman65_79
Aug 7, 2015 09:55 PM
