can anyone decode these casting #'s for me
Car: Black 88 Iroc Convertable
these are the #'s i have i hope there the right ones there for a small block that is in a 77 vete i want to know if the motor is a vette motor
v03010cla the zero's may be o's
17542568
Keith
85 Berlinetta WS-6
87 Cougar 20th Anniversary
[This message has been edited by cougar20th (edited November 18, 2000).]
17542568
Keith
85 Berlinetta WS-6
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
CLA is for a 1977 corvette 350 but the engine code was also used on many other models and years.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
454 Big Block buildup now in progress for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car
91 454SS daily driver
95 Homebuilt Harley
Best 60 foot: 1.662
87 IROC bracket car
95 Homebuilt Harley
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Originally posted by cougar20th:
v03010cla
v03010cla
0301 = March 3rd (I think you have an extra 0 in there
)CLA:
1973 (vin L = 190hp), L48, auto TH400, 4bbl, Vette
1974 (vin L = 195hp), L48, auto TH400, 4bbl, Vette
1977 (vin J = 180hp), L48, auto TH400, 4bbl, Vette
17542568
7 = 1977
your missing a letter I think. The assembly plant (ie: N = Norwood)
542568 = vehicle sequence
This number should match your Corvette's vin numbers to be a "numbers matching car". Otherwise, it was replaced.
EDIT This info comes from a Camaro resource site (gotta give credit where credit is due
). MadMike's------------------
George P. Lara
1994 Z28 LT1 T56
1984 Z28 High Output
Member: SCCA, SCFB, SC3GFB
[This message has been edited by MRZ28HO (edited November 19, 2000).]
thanks mrz28 sounds like it should be original i just need to check the vin next time i see the car
Keith
85 Berlinetta WS-6
Keith
85 Berlinetta WS-6
skinny z
Oct 5, 2015 06:23 PM
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
355tpipickup
Sep 13, 2015 11:35 PM
