How do i check if my engine has seized?
Old Nov 20, 2000 | 01:15 AM
ghostkilla2179's Avatar
I have an 89 IROC-Z, 350 5.7 TPI. How do i check if the engine has completely seized up? I have heard about turning the crank with a breaker bar. If i was to do that, what equipment would i need? What size is the nut on the crank wheel? Is there any other way to find out if the engine has completely seized up? as of now the starter will not move the motor at all. I can tell this by watching the alternator while i turn the key. Any info is greatly appreciated.
Old Nov 20, 2000 | 07:45 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
You can turn the crank with 2 methods:
1) Breaker bar with a 5/8 socket on the end.
2) Remove dust cover at trans and turn it with a flywheel tool.
Make sure you pull the plugs first so its easier to turn. (if it will )
What happened to make you think its siezed??
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
Old Nov 20, 2000 | 04:51 PM
ede's Avatar
ede
i'm locking this since it's a double post.
-=ICON MOTORSPORTS=-
1st & 3rd
colton_carlson
Mar 8, 2019 12:21 PM
Infested
May 22, 2018 11:56 PM
Reddeath210
Oct 6, 2015 08:20 AM
dutch930
Sep 11, 2015 06:58 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
