Fuel Pressure drops immediatley
Old Sep 22, 2003 | 03:52 PM
strider681's Avatar
Car: '87 Pontiac Trans Am GTA
Engine: 350 5.7L TPI (L98)
Hey guys, I have a 87 trans am TPI 5.7L and here is my problem. Comming out of my complex friday my car dies in the middle of a turn. well I get it over to the side of the road and start checking it out. first thing i hooked up a fuel pressure guage and read 0 psi. so i replace fuel pump relay, now get 41 psi while pump runs, then drops quickly to 0. now i took the old feul pump relay, took the cover off, and noticed when i remade the connection it would hold the pressure. so it's only holding when the pump is running. just to make sure i replaced oil pressure/fuel pump switch located near oil filter. no change. rebuilt pump relay connector, no difference. took fuel rail completely apart, replaced all o-rings and pressure regulator, no difference. at this point, the only thing left seems like the pump itself. i read in another post that there is a built in check valve for the pump? sounds like it may be it. i was also wondering if anyone knew if the tank pressure control valve hooked to the canister could affect this?? last thing, in order to check if injectors are laeking, do you have to have the wiring connected? any help is definat;ey appreciated, I'm almost at my wits end!
Old Sep 22, 2003 | 06:05 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Sounds like the check valve to me. Leaking reg could also do it. But, the pressure should be trapped when the pump shuts off and the injectors aren't being pulsed.
Old Sep 25, 2003 | 08:40 PM
strider681's Avatar
alrighty here is the skinny, after putting my car back together and trying to crank it, the fuel pressure stays right about 40. Now I noticed there was no spark, (which I should have checked frist) so I found the distributer control module was bad. at Autozone they can test those things. only 23 bucks for the part. so this was my problem all along.
Old Sep 26, 2003 | 02:12 PM
five7kid's Avatar
Amazing how many fuel problems are fixed by replacing ignition parts.
Glad you got it figured out.
Old Nov 1, 2005 | 06:11 PM
strider681's Avatar
as far as the pressure dropping off I had to replace my fuel pump and the pulsator to get 44 PSI that actually holds steady now with the pump not running
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
