How do i get dipstick tube out?
Old Oct 30, 2005 | 06:37 PM
crazy3rdgen's Avatar
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
The motor's pulled so its easier to work with other then the fact its not on a stand. I went to take off the crappy manifolds on this 305 tpi and on the passenger side the bracket for the dip stick tube was pissing me off, i bent the whole thing up and took a hack saw to it hoping to just be able to get a new one. Hows this thing come out? I pulled on it but no budge? Where should i get a new cheapy one at?
Old Oct 30, 2005 | 09:10 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Mine just took a bit of wiggling and pulling and it popped out...
Any autoparts store should be able to get you a new one, you can even get chrome ones if you like bling.
Old Oct 30, 2005 | 09:13 PM
Car: 2002 SS
Engine: Ls1
lol bling bling. i'll try tomorrow to get it out and i'll let yous know if it goes good or bad.
Old Oct 30, 2005 | 09:18 PM
RocBoy's Avatar
Car: 85 IROC Ht
Engine: 383 carb
Axle/Gears: Moser 12 bolt 411
You could put some heat too it . Use your own judgement as to how much .
Old Oct 30, 2005 | 11:20 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Hammer
Old Oct 30, 2005 | 11:39 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I used vice grips on mine and just started pulling outwards and side to side. It eventually gave. Wasn't the easiest though because I did the same thing you did, but it was still in the car so I had to run out and buy a Lokar braided one. Okay, I could've bought one of the chrome ones at the store, but I don't like chrome and wanted a stainless braided one (not to mention they didn't have one for '87-up cars at the store).
Then when I pulled the 305, I couldn't use that stainless braided setup because I have an old block that uses the driver's side dipstick setup and I wasn't going to buy another braided setup so I had to settle for chrome. That and my oil breather are the only two pieces of chrome on my car. The cheap chrome stuff is cheaper/easier to get than non-chrome stuff sometimes it seems
Oh, and when you put a new one back in, put a dab of black RTV sealant around where it will butt up to the hole in the block. Oil shouldn't get to there anyways with the press fit (speaking of which, you may need a rubber mallet or something to tap the new one in), but the RTV is a nice little extra precautionary thing I did.
Old Nov 1, 2005 | 03:07 PM
Car: 2002 SS
Engine: Ls1
alright cool i got the thing out with vise grips. Went up to autozone to get one of those chrome ones for like 10 or 12 bucks and the damn things sold out. And they said, come back next weds. Psh
Old Nov 1, 2005 | 06:30 PM
firebird45331's Avatar
Car: 86 Firebird, 2002 Monte Carlo, 91 v
autozone sucks donkey dong when you need a part and they won't have it until next monday. Thank *** we have an advance here that'll have it for me tomorrow.
Old Nov 1, 2005 | 06:39 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Definately use some RTV on it when you put it in, I didnt on mine and when you get the revs up it pukes oil right onto the collector of the header. I though for sure my new motor was toast then i looked around and saw my header was coated in cooked oil dripping from the dipstick!
gixxer92
May 18, 2017 11:20 AM
no green
Jan 9, 2016 09:22 PM
NZKnight
Oct 15, 2015 02:47 PM
FormulasOnly
Oct 2, 2015 05:52 PM
zman1969
Oct 1, 2015 11:09 AM
