When I start modding....what should I start with??
Old Nov 20, 2000 | 02:37 PM
a1987formula350cu's Avatar
Right now my car is 100% stock down to the air cleaner. I was thinking exhaust but someone said gears and I may lose low end power w/ the headers and 3" exhaust. What should I do?
1987 Firebird Formula 350[*]Stock except...[*]Cragar Street Stars
My Car Website w/ Pics
fyrebird350@hotmail.com
AIM/AOL: FIREBERD350
<<<<---THIS CAR IS FOR SALE(only 49k)--->>>>
Old Nov 20, 2000 | 04:30 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
shift kit,high stall torque converter,4.11 gears,cam (to accomodate the lower gear ratios),MSD ignition,underdrive pulleys,K&N,polygraphite bushings......just some ideas in a logical manner get educated before you waste money,this is a great place to start. save your car too, thats the best mod,theres no sense in investing $$$ in your ride if your going to race it into the ground in three months flat.factor in the cost of speeding tickets.always take care of your brakes/steering first!
Old Nov 20, 2000 | 11:31 PM
irocz's Avatar
Car: '87 IROC-Z
Engine: 406 Superram/DFI
Transmission: Auto BTE 3000 conv
What rear do you have? If it's a 9 bolt you're screwed. You can get used 3.45s out of a 5spd car or spend about $400 for a set of 3.70s. I wouldn't worry about the rear for now. You need to get K&Ns, airfoil, afpr, port your plenum, gut the cat, get a good (not edelbrock) catback, and then get a good (not hedman) set of headers. Headers should come last.
87 IROC-Z, 5.7, auto, 3.27, leather, !cat, Holley fpr, K&N'S, SLP 1-3/4" Jet-Hot coated headers, SLP .218/.224 .495/.502 cam, Comp 1.5 roller tip rockers, $uperPITAram, Edelbrock lower intake, Holley 52mm tb, Dynomax\Flowmaster catback. Coming Soon(?)- Fasttrack/Accell DFI
1989 Pontiac 20th Anniversary Turbo Trans Am - 160,000 miles, K&N filter
Old Nov 21, 2000 | 02:50 AM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
personally i dont think you should mess with gears until the later stages of modding.
because by the time your done with your engine and tranny, you will better be able to know where your powerband is and can select the right gears for your application (street or strip or both?)
btw unless you have a T56 trans, 4.10 gears are WAY too much.
I would start with intake and exhaust first. free up your intake with K$N, airfoil, port the plenum, afpr. then get a full exhaust like you said. 3" is good, 2.5 would probably better for low end torque, and headers. then you can get your tranny to shift quicker. with either a shiftkit(auto) or some sorta short-throw shifter if your manual.
dont mess with a Torque converter until your motor is "completed" again the powerband arguement.
good luck!
1982 Camaro Z28...$1000
Vortec 350 block rebuilt 20 over.. $900
L31 Vortec heads...$0 xtreme energy comp cam... $200
Edelbrock carb/intake...$500
home made cold air/ram air induction...$0
dynomax headers...$150
flowmaster 3chamber...$250
rebuild diff, 3.73 richmond swap... $900 built 7004r w/ stock converter... $200
Dusting a 2000 GT with my "truck motor"...
PRICELESS
Orr89RocZ
Apr 25, 2016 08:28 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
