Tall valve covers needed? .575 lift?
Old Sep 22, 2003 | 10:24 PM
Abubaca's Avatar
Straight forward.
Do I need new valve covers for increased lift of .575???
Old Sep 23, 2003 | 05:41 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No. At least, not from the lift itself.
You may need them if you use rockers that have any chance of surviving, however; nearly all rockers that can move that far will use Poly-Locks, which are too tall to fit. Or, if you have roller rockers and center-bolt valve covers, the thing for the bolts might not fit down between the rockers; or, the oil baffles for PCV may not fit in there either.
Old Sep 23, 2003 | 07:03 AM
Abubaca's Avatar
I'm planning on going with the Vortec TPI set-up from Scoggin Dickey. I think they set-up the heads with the LT4 valvetrain. I'm still researching, and I want to cover all bases.
Old Sep 23, 2003 | 12:01 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
You can always be cheap and do what I did...grind out the baffles on the stock valvecovers. I've got a set of 1.6 full roller rockers with poly locks and they fit under the factory valvecovers. Very sleeper. Course you've got a LOT more lift there than I do so that still might not work with those rockers.
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
Street Lethal
Aug 12, 2015 11:33 AM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
mustangman65_79
Aug 8, 2015 01:18 AM
