Blown Head Gasket? Symptoms?
Old Sep 26, 2003 | 08:30 PM
Trickie's Avatar
Blown Head Gasket? Symptoms? **UPDATE** PICS
Ok, I had been having a problem with pinging anywhere past half throttle for a long time now and basically stopped it by retarding timing...
Yesterday I ran the car down the road and back and when i turned off the car i noticed coolant spewing out of the overflow resevoir.
I let the car cool down a little, opened the cap to the radiator and noticed it was full of white foam. Put the cap back on felt the upper hose while running and it was pulsing somewhat.
I am getting no smoke out the back, some of the plugs show signs of running lean.
How can i determine if i actually have a blown head gasket or not, compression test seem normal, and if i do have a blown head gasket how do i determine which cylinders are affected.
BTW 88 firebird 350 swap tbi
Old Sep 26, 2003 | 09:18 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Pressure test the cooling system. This happened to a buddy's car, he blew a headgasket, and it was blowing compression out into the cooling system. There's also some type of way to test the cooling system for exhaust gas.
Old Sep 26, 2003 | 09:41 PM
Trickie's Avatar
I did do somewhat of a pressure test, how much psi do you normally have do pump into the cooling system to see if you're leaking?
Old Sep 27, 2003 | 02:15 AM
Morley's Avatar
just fill the radiator,leave the cap off, start the car and look for lots of bubbles coming to the radiator neck.
A quick way to test which cylinder it is would be to remove the spark plugs, get an air adaptor that screws into the plug hole, put compressed air into the cylinder (make sure the valves are closed for the one beig tested) and watch for the bubbles in the radiator again. (I just went through this 6 months ago)
Old Sep 27, 2003 | 10:08 AM
Trickie's Avatar
thanks guys
Old Sep 27, 2003 | 10:20 AM
ede's Avatar
ede
run a compression test along with testing the cooling system
Old Sep 27, 2003 | 03:02 PM
Trickie's Avatar
I took the suspected head off and took some pics, please tell me what this looks like to you guys...
Old Sep 27, 2003 | 03:54 PM
Morley's Avatar
Yep, you blew the end of the head gasket.
3rd gen money
Sep 8, 2015 11:40 PM
earlpote
Aug 28, 2015 10:42 AM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
