fuel pump and leaking fuel tank
Old Nov 23, 2000 | 06:24 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
I just spent $600 to have my fuel pump and gas tank replaced. After 128,000 miles, the fuel pump just died with no warning. I brought it to the shop and when they took it apart, the fuel tank was cracked at the filler neck. The fuel tank is in a really bad place. My exhaust was completely welded(dual cats), so they had to cut it off, and the most of the rear suspension had to be removed. 4 hours of labor.
$130 pump
$140 tank
$220 labor
$50 exhaust repair
plus tax and environmental charges
I've heard that cracking fuel tanks is a common problem. Did GM ever recall this, or was there a secret TSB about it? It seems to be a safety issue. The thing was probably leaking for years and I didn't know it. Not a good thing since the muffler is right underneath.
89 Transam GTA, a few bolt ons
Old Nov 24, 2000 | 07:28 AM
SeanSullivan's Avatar
There was a svc bul on the 92 filler neck, you might as well call the local dealer see if your car was included in that and if it was repaired. The phone call is free.
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
