Help me on a Cavalier
Old Nov 21, 2000 | 01:40 PM
82z's Avatar
82z
So here's the deal, my roommate's Cavalier (89 with a 2.0 vin 1 distributorless) leaked coolant at the front drivers side corner. I replaced the gasket no problem. Now the reassembly is gettting me. Mitchell says to give the valves 1.5 turns after 0 lash. No problem right? Well the adjusting nuts stop turning just short of 1.5 turns. My teacher says that the valves are net lash and just get tightened down. I think he is right but what about you guys? Also he says the head bolts are torque/angle in a blind hole but I believe that the are standard bolts in a wet hole. Mitchell gives me straight up torque specs, one for the long and one for the shorts(I forgot what they were). What do you think? Help me out here guys, my roommate needs a car. Thanks
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi, manly b&m megashifter
Old Nov 21, 2000 | 01:53 PM
amagin86's Avatar
I've had A LOT of problems with the head gasket on a 2.0 cavalier. hayne's said to torque the bolts to some value (i forget, can look it up if you want/need it) and then turn each bolt an additional 90 degrees (a shop mechanic backed this one up). As for the valves i just took them off and put them back on per hayne's. didn't have any problems wiht the valve train but the thing keeps overheating even after a new ratiator and stuff, guess i'll do the waterpump again!?
hope i helped at least a little
alex m
columbia mo
The world is full of stupid people...and I am no exception.
'83 Z28 5 speed (regrettably with T-tops)
'83 Z28 No T-tops (regrettably automatic)
Old Nov 24, 2000 | 04:25 PM
82z's Avatar
82z
What did Haynes say? Do they even make Haynes books for these cars? I've never seen them.
Old Nov 24, 2000 | 04:45 PM
84IROC's Avatar
Chiltons says, Rocker arms get 11-18 Ft. Lbs. There are no other instructions so I presume that no other preliminary lash adjustment is required. Just tighten the nut till the desired torque is achieved.
head bolts,
VIn code (K) 18 ft. lbs. then 3 turns of 60* each then 30-50* after warm-up.
Vin code (M) same as above
vin code (1) short bolts 62-70 ft. lbs. long bolts 73-83 ft. lbs.
Vin code (W) 70 ft. lbs.
the vin code is the eighth didgit in the VIN #.
'84Z28/'92 305TPI
'92 complete rear suspension/PBR disc/Posi/3:42
Light weight 34.5mm stabilizer bar in front
23mm sta. bar in rear
rear lowered 1" by cutting 1 1/4 coils of '84Z28 springs
comp cam, flowmaster
TB coolantbypass/shutoff valve to heater core
MAT relocated
Ram-Air(home-made) gutted air-box
IROC ground effects/wheels GY245/50's
700R4 superior shift kit/ corvette servo(excellent shift kit BTW) Rebuilt engine and transplanted it myself. Love this engine!
LOW performance people should drive low performance vehicles!
Paul_Hughes_87 T/A
Nov 8, 2001 01:56 PM
CamaroX84
Jul 16, 2001 07:56 AM
TC602
Jul 2, 2001 08:49 PM
Drew305
Sep 14, 2000 08:10 PM
