Someone explain this to me
Old Sep 28, 2003 | 10:46 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
I was thinking when you do a chassis dyno test you have it in 4th gear for a 1:1 ratio. I was wondering if they take the rear ends ratio to give the final #.
Old Sep 28, 2003 | 11:10 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
I don't think rear gears matter at all during dyno tests.
Old Sep 28, 2003 | 11:15 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
it shouldnt make any difference....its a 1:1 ratio, so you eliminate all gear advantage except at the rear end....but the variance isnt enough to make a significant difference in dyno numbers...cause all cars are pushing the same load on the dyno rollers
Old Sep 29, 2003 | 05:43 PM
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
so the same car with 4:11s and 2:73s would put the same #s to the wheels?
It seems weird to want a direct drive through the tranny but not through the rear.
Old Sep 29, 2003 | 06:00 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
no, they won't put the same power to the wheels.
Old Sep 29, 2003 | 06:42 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The same power will be measured (neglecting any trivial difference in losses between the two gear sets), but the 4.11's will have 1.5 times the rear wheel torque.
The pull can actually be made in any gear. The dyno corrects for gearing to give flywheel torque rather than rear wheel torque by inferring the ratio from the engine RPM and rear wheel speed of the car.
Old Sep 29, 2003 | 08:50 PM
25THRSS's Avatar
The dyno still gives rwhp and rwtq #'s.
Old Sep 29, 2003 | 09:14 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
Re: Someone explain this to me
4th gear is 1:1 in a manual tranny. 3rd is 1:1 in auto.
i've done a second gear run and a 3rd gear. gained 7 peak hp in 3rd (auto) and gained 71.1 peak tq
Pac J
May 17, 2020 10:44 AM
Ed1LE
Sep 30, 2018 09:14 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Cacike
Aug 27, 2015 05:10 PM
