A weird sound coming from under the hood
Old Nov 24, 2000 | 02:11 AM
ollie-999's Avatar
Hey for the past two days i keep getting a sound when i press the peddle a bit..
then when i go full or half throttle it stops..
it sounds like a howling or screchin sort of sound?
any idea what it could be?
i replaced the belt like in auguest so i dont think it should be the problem
91' Camaro Rs
Old Nov 24, 2000 | 08:04 AM
jrr's Avatar
jrr
Man, are you sure that belt is tight? I don't know much about your car, but if you have an idler pulley, see if it's frozen up. If that's not it, I'll bet your alternator or water pump is slipping.
Many, many, MANY years ago, I had an old Volvo wagon as a parts go-fer and all around beater and the belt tension pulley froze up and the belt started howling like you described. Of course it was smoking too!
Old Nov 24, 2000 | 08:20 AM
B84305-Streetmachine's Avatar
i remember once that sound was coming from a POS power steering pump.....it siezed and threw a belt overheated the engine...and when he put a new belt on it....it would just screech every time he gassed it.....hmmmm
Old Nov 24, 2000 | 09:43 AM
bleak's Avatar
water pump slipping. maybe alternator, but if it's constant, water pump. power steering usually groans instead of screaming.
Old Nov 24, 2000 | 08:26 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
It's not very uncommon for the serpentine belt tensioner to seize up. I've replaced quite a few of them. Try to loosen it as you would to change the belt, then let it loose. It should return back to the belt, and have some tension on it.
Good Luck!
Working on:
'84 Z28 LG4 305
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350
using primarily GMPP parts.
Block is in shop!
Awaiting results from all 8 ASE tests.
Starting to look like the Kicker poster child!
Frozer!!!
Jan 19, 2024 04:55 PM
Cleotiz
Jan 6, 2018 08:56 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
db057
Aug 22, 2015 08:17 PM
gwade12
Aug 8, 2015 08:17 AM
