coolant cleaning stuff?
Old Nov 24, 2000 | 04:43 PM
Sweet_85_Bird's Avatar
I saw this stuff at wal-mart,think it was prestone,that said it got rid of rust and all that out of the cooling system.My question is does it work.It said you drain the coolant put this in w/water and drive for 6-10 hrs.Also,when i do flush out my system where are the 2 drain plugs on the engine at(2.8l).
Old Nov 24, 2000 | 05:55 PM
ede's Avatar
ede
never used it but i'd say it would help, or wouldn't hurt. i think you'll get most of the effect from just flushing the system. not sure on your engine but i'd look for a pipe plug just above the oil pan rail about the middle on the block.
-=ICON MOTORSPORTS=-
1st & 3rd
Old Nov 24, 2000 | 09:04 PM
johns84bird's Avatar
Car: Pontiac Grand Prix GTP
Engine: 3.8L V6 SuperCharged
I've used this stuff, it seems to work well. You dont drive it for 6-10 HRS (I hope that was a typo) it's minutes. just run it till it reaches normal op. temp and then for another 6-10 min. so it gets to all parts of the coolant system. I used prestone's reverse-flush kit that you use a hose with. You don't have to mess with the plugs on the block, it all comes out the top of the radiator. Hope that helps - just follow their directions carefully.
84 Firebird with Trans am ground effects- 350 4bbl GM crate motor (LM1), T-Tops, automatic, K&N filter, 180* thermostat, ram-air hood scoop, flowmaster muffler, Accel cap & rotor, MSD Super Conductor Wires. Coming soon: new interior (grey), rear end work, subframe connectors, polyurethane bushings
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
89 formula TPI
Oct 6, 2015 08:40 PM
Nick McCardle
Sep 10, 2015 08:36 PM
