Car will not start (open to any sug...)
Old Nov 16, 2000 | 11:25 PM
rudedude's Avatar
I gotta 86 bird, 2.8L. It will crank, crank but will not start. I'm not the world's best mechanic but i have checked for fire and fuel. I got plenty of fire to coil. I got fire to plugs but i can't tell if its as strong as it should be. I can hear the fuel pump and relay kick on and i got fuel to the pressure relief valve. I checked the codes on the computer and the engine light repeatedly flashes 12. In which i believe that to mean that the ecm is functioning. Well i tried some part swapping (cap,button, ignition module,ecm). i even did a ohms check on pickup and it seems to be within limits. The day before it quit it ran great no problems then bang it just will not start. any suggstions????
Old Nov 17, 2000 | 12:14 AM
89 CamaroIROCZ's Avatar
If you have fuel and spark the next place i would check is for injector pulse. Then timing. An engine only needs three things to run and thats fuel, fire, and timing.
Matt
89 Camaro IROC 5.7L 350"
ZZ4 Performance Cam, K&N Air Filters, 160 stat, Ported Plenium, Hypertech Airfoil, TB Coolant bypass, B&M Stage II Shiftkit
New engine on its way with a HOLLY instead of all this TPI crap.
Old Nov 17, 2000 | 07:59 AM
82camaro's Avatar
Car: 82 camaro SC
Crank it for a few seconds and pull a couple spark plugs and see if you are getting fuel into the engine.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Nov 17, 2000 | 11:32 PM
raven350's Avatar
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
something could have happened to the timing where it is advanced to far for the motor to start.
Could also be the SKIM(Sentry Key Ignition Module) module or relay is bad. I had to ground out my relay to get my car to work.... Relay is still grounded to this day...
Old Nov 17, 2000 | 11:53 PM
mtx28's Avatar
check all vac. ports... i had a hose unplugged and couldnt drive mine for a month cuse i didnt see it, its not my daily driver thank goodness
Old Nov 17, 2000 | 11:54 PM
mtx28's Avatar
Old Nov 18, 2000 | 12:58 AM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
you should find out what 12 means.built in test equipment,it's there for this reason.
Old Nov 18, 2000 | 01:40 AM
CamaroZ_85's Avatar
12 means the computer is functioning properly
350, Comp 262, Edelbrock Performer intake 600 cfm carb and exhaust, headers
Old Nov 18, 2000 | 12:52 PM
Corry's Avatar
Car: 1987 Trans Am
Axle/Gears: 10 Bolt SLP Torsen, 3.73 ratio
if all else fails, it could be something major. If nothing else seems to work, run a compression test on it. Other than what's been mentioned, I am not sure what it could be...vader can probably shed some light on the suject.
Corry
Old Nov 20, 2000 | 08:08 PM
rudedude's Avatar
I finally got a chance to check it out some more. I got fire. Fuel up to pressure relief valve but no gas from injectors. I can still hear fuel pump and relay. I am going to check fuel pressure as soon as i get a gauge. Could the pressure regulator cause no gas to injectors???
Old Nov 21, 2000 | 12:48 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
As previously suggested, check to see if you are getting pulses to the injectors. This is really easy to do, all you need is a test light, which is a lot cheaper than a fuel pressure gage. Just unplug one of the injector harnesses and touch a grounded test light to the positive terminal on the harness. If the light flashes then you are getting pulses to the injectors. If not then the computer is probably bad.
Old Nov 24, 2000 | 09:22 PM
rudedude's Avatar
Thanks for the advice. I used a test light to see if injectors were pulsing. They were 'nt. The problem turned out to be in the wiring harness to the injectors. She runs like a scalded dawg again (for a 2.8 that is!!).
Ghettobird52
Jul 5, 2024 11:18 PM
midge54
Dec 27, 2019 04:14 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
killer777
Aug 8, 2015 02:47 PM
