Code 32 and 36
Old Sep 29, 2003 | 02:04 PM
Greygoat's Avatar
Code 32 and 36
Just wondering if anyone out there knows how to fix codes 32 and 36.
Old Oct 6, 2003 | 04:48 PM
Greygoat's Avatar
recently i changed my coolant sensor cuz it was giving me a 15 code and also it was giving me a 21 code, so i fixed those problems. Then i disconnected the battery to reset it. So now it gave me a code 32 and 36 and my car is has high idle can anyone please help.
Old Oct 11, 2003 | 01:19 AM
Greygoat's Avatar
how do u check if our IAC or MAF is going bad
Old Oct 11, 2003 | 01:56 PM
Morley's Avatar
There is a resistance check for the IAC (don't know it off the top of my head). To check the MAF, get the car running and GENTLY rap the MAF housing with a screwdriver handle, if the engine stumbles or stops acting up when you do this the MAF is probably bad. When dealing with the MAF, ALWAYS, ALWAYS, check the electrical connectors before paying $150 for a reconditioned one. This goes for all electrical troubleshooting, always check the connections before replacing a component, it'll save you lots of time and trouble.
Old Oct 13, 2003 | 09:18 AM
Greygoat's Avatar
I did tap on the MAF and it did not do anything, but the other day i took it to a mechanic and it started to run fine. We reset the computer and now the check engine light is off now. I dont know but i thing my car is playing games with me.
Old Oct 13, 2003 | 09:25 AM
Greygoat's Avatar
so how do u trouble shoot the IAC
Old Oct 13, 2003 | 11:23 AM
Morley's Avatar
One quick way to check it to see if it is even moving would be to put a jumper between pins A&B of the ALDL and turn the key on (don't start the car), then go and listen to the IAC, it should be making a clicking noise. If it isn't it is probably bad ( would need to ohm out the coils from pin to pin), if it is clicking it should be ok, but may need a good cleaning of it and the throttle passages it sits in.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
