Can I get 16 ohm resistance injectors?
Old Nov 24, 2000 | 10:40 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
MSD sells 22lbs PN 2017 and was wondering if 16 is to high or is ther a differance?
PN 2010 21 lb/hr12V Saturated Circuit12 Ohms
PN 2011 26 lb/hr 2 Ohms
PN 2012 34 lb/hr 2 Ohms
PN 2013 50 lb/hr 12 Ohms
PN 2014 72 lb/hr 4/1A Peak & Hold 2 Ohms
PN 2015 96 lb/hr 4/1A Peak & Hold 2 Ohms
PN 2016 19 lb/hr12V Saturated Circuit16 Ohms
PN 2017 22 lb/hr12V Saturated Circuit16 Ohms
PN 2018 38 lb/hr12V Saturated Circuit12 Ohms
PN 2019 24 lb/hr12V Saturated Circuit12 Ohms
Old Nov 24, 2000 | 11:37 PM
Vader's Avatar
Mkos,
16 ohm injectors should be just fine. Factory 19- and 22-lb/hr injectors have a load resistance of 16 ohms, so getting an identical solenoid coil should be a good thing.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old Nov 25, 2000 | 10:57 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
In fact, low impedance injectors may not work with your ECM.
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
